greddy emanage
The emanage blue does, but the ultimate doesnt.. Several members have tried to get it to work an US proteges with no success..
I was planning on getting emanage for my car but after a recent event that happened today.. Looks like all my plans are no longer..
toughen up man and start looking for your baby around, don't just wait and see what turns out.
to the other guy
Emanage will work if you make it to work, simple as that. If you know what you doing you'll make it work but that's no guarantee if it will stay working or s*** on you.
the emanage from what i have heard on our cars is very tempermental and likes to not work right from time to time. o and if you do decide to go the emanage route dont forget the o2 voltage clamp
no e mange blue can do timing, fuel, and tune off a 3 bar map sensor and can datalog more than afr's if i remeber correctly
you can run one but you need the harnesses and a o2 voltage clamp if you want it to work correctly. because with out that voltage clamp the msp ecu is gonna to override anythign that you do and start changing afr's. really if you want ot talk to someone thats had it and ran it you should talk to Alejo_NIN
yea but he couldnt get it to stay tuned either I was in the same place i think microtech is where its at for these cars :(
Its not the e-manage that changes settings, its the ECU. For example tune
will change when the car is started cold opposed to already warm.
