garret2331
- Mazdaspeed 3
I think its the bracket to the brake lines not sure but when I tried to go at lowest the lock ring was gonna hit the bracket.
yea, I know what you are talking about. I was looking at mine out of the box and it looks like the threads were put into the shock body before the bracket was welded on.
I vaugly remember someone noting that you can't get to the lowest recommended setting due to interference with the bracket in question.
Without the helper springs you'd be scraping....maybe thats what you want![]()
Having a little issue. My front left ( I think ) is making rubbing noises. sometimes it makes the noise when I am just turning mildly. Do you think im rubbing on the inside, or do you think im too low?
Same issue here but mine does the right side. Im rubbing when i turn the steering wheel all the way. Im running 235/40 tires not yellow said thats normal.
well it started happening more often after a week.
I finally have money for wheels, going with 18x8.5 +30, do you think 225/40 will work good?
