GHL Pricing and Info
Since the last two threads have gotten to big Im starting a third to keep confusion down.
The GHL turboback is a true turboback from the flange off the turbo all the way to the tip. Its made of RATH T304 stainless steel and carries a lifetime warranty. Included in each system is an OBD II compliant cat and a center resonator for volume control. Our mufflers as well as all other pieces are built in house.
Options include:
3"Downpipe Only W/Cat (bolts to factory catback)
3"Downpipe W/Cat Delete (off road only)
3"Catback W/Resonator
Just the S pipe which really doesnt bolt to anything
Cat and or Resonator delete pipes for the turboback.
Pricing:
3"Full Turboback $995 shipped (intro)
3"Downpipe W Cat $538
3"Downpipe W Cat Delete $485
3" Catback W/Resonator $595
Just S pipe $385
I hope this clears up a lot of questions.
how much for just the cat delete pipe? and does the downpipe include the o2 sensor bung?
i think you forgot to mention the cost for the entire turboback minus the muffler? i hope thats still a option
sorry, i mean just the pipe between the downpipe and catback, that contains the cat. how much does it cost for just the pipe, without a cat, so that if i bought the downpipe + cat, i could also have the pipe to switch out with the cat so that i have the option to run catless. then i can just switch back out with the cat piece.
Pricing for this setup by the end of the day.
No, only the complete turboback is priced with shipping included. I can't believe I've been following all these threads about this exhaust. I should just become a GHL spokesperson. So GHL, when are the products going to be up on your website?
if i want a pipe that goes from turbo to my stock muffler what do i need to buy???
3"Downpipe W Cat Delete $485?
and also does your piping go?
turbo -> downpipe -> cat -> resonator -> muffler
or instead of cat/resonator you get a pipe right?
turbo -> downpipe -> extra piping -> muffler
Best I can say is soon, our servor is based in Florida and they are playing a bit of catch up from the storms. I'll be around answering questions since I know its a pain not to be able to check out the site.
Phill
You would need to buy the full turboback minus the muffler.
Your diagrams are correct.
What about those with corksport exhaust systems. The corksport exhaust starts after the J-pipe. When you say just the S-pipe will be available, will this s-pipe replace the stock j-pipe or would i have to connect the s-pipe to the stock j-pipe? I'm only asking because I am about to pay 339 for my corksport exhaust and i really really like this s-pipe. If you aren't clear on my questions, please post a reply and i will try to clarify. I have read through all the posts about this exhaust and i wasn't able to find a definitive answer on whether your s-pipe will work with a CS exhaust system.
EDIT:
If you look at this picture you will see what im referring to...
http://www.corksport.com/content/00/01/06/61/73/uploaded.files/exhaust2.jpg
Notice the silver piece, that is what i am calling the J-pipe. That small piece that connects the S-pipe to the "mid-pipe". It is silver in color and has an O2 sensor in it. Just want you to clarify whether or not your s-pipe will replace this piece or not.
EDIT2:
QUESTION ANSWERED. For those of you with CS systems, you can use this s-pipe which DOES replace the factor s-pipe and j-pipe HOWEVER it will not come flanged so you would need to have a flange welded on to it, or simply have your CS exhaust welded directly to the DP.
Just buy the DP (looks like it is one section all the way back to the cat-back location), toss your CS mid-pipe, and used the rest of the CS exhaust to go with this. Or, you can sell your CS exhaust on e-bay and buy the whole turbo-back. It would be restrictive to mount this 3" system up to your 2.4" CS piping anyway.
EDIT:
GHL:
Is your DP that mounts to the cat-back one or two pieces? Also, would it come with some kind of flex-pipe so the movement doesn't rattle everything loose?
