Gauge Needle Repair
I know its not possible to swap odometers --- we checked into that. Mazda said they cant reprogram the cluster odometer so thats outta the question as well (which is why they said it doesnt matter since the ecu holds the true mileage anyway). As for swapping just that part of the cluster into the current (broken) one ... that MIGHT be possible but you dont want to have 2 broken clusters now do you?
Pe@ce
You can switch odometers.!!!
You can rebuild the whole cluster. I have my Pro5 odometer redone w/ black guages from the 99-00 sedan. I also used the smoother surround from the sedan. I also switched the lights so it is red instead of green. It's not that hard...I could walk people through it if I had to.
