gas cap issue is now finally a recall
2001 BJFP MT
2016 BMYFS AT
TSB: 01-001/07
2007 CX-7, 2006-2007 MX-5, 2006-2007 RX-8 - MAZDA SPECIAL PROGRAM (MSP13) - MIL ILLUMINATION WITH DTC P0455
APPLICABLE MODEL(S)/VINS
2007 CX-7 vehicles with VIN JM3ER29**70100057 - JM3ER29**70128616 (built from February 14, 2006 through August 1, 2006)
2006-2007 MX-5 vehicles with VIN JM1NC**F*60111723 - JM1NC**F*70125568 (built from January 6, 2006 through August 2, 2006)
2006-2007 RX-8 vehicles with VIN JM1FE173*60200012 - JM1FE173*70208462 (built from January 7, 2006 through August 2, 2006)
DESCRIPTION
It is possible that a malfunction indicator light may illuminate with DTC P0455 (EVAP System Leak Detected-Large Leak) stored in memory, due to poor sealing between the fuel filler pipe and fuel filler cap.
NOTE:
  • UNDER THE MAZDA SERVICE PROGRAM (MSP13), ALL CURRENT DEALER INVENTORY AND RETAILED VEHICLES FOUND TO BE WITHIN THE ABOVE PRODUCTION AND VIN RANGES MUST BE INSPECTED AND REPAIRED ACCORDING TO THE INSTRUCTIONS CONTAINED IN THIS SERVICE BULLETIN. THIS INCLUDES CUSTOMERS WHO HAVE BROUGHT THEIR VEHICLE IN FOR NORMAL SCHEDULED MAINTENANCE AND/OR OTHER SERVICE WORK THAT MAY NOT BE RELATED TO THE CONCERNS OUTLINED IN THIS BULLETIN.
  • BEFORE PERFORMING ANY REPAIR, VALIDATE THAT THE VEHICLE IS APPLICABLE TO THIS PROGRAM BY PERFORMING AN "eMDCS" WARRANTY VEHICLE INQUIRY "AND VERIFYING THE VEHICLE DISPLAYS CAMPAIGN "MSP13" AND ITS CAMPAIGN STATUS DISPLAYS "OPEN". SEE "VEHICLE INSPECTION PROCEDURE" BELOW.
DEALER INVENTORY:
Repair all applicable vehicles currently in dealer inventory according to the procedures contained in this service bulletin.
RETAIL VEHICLES:
When an applicable retail vehicle is brought into the dealer for any type of repair or scheduled maintenance, perform an eMDCS Warranty Vehicle Inquiry and check the status of MSP13. If status of MSP13 is "OPEN", repair the vehicle according to the procedures contained in this service bulletin.
1. Verify the vehicle is within the following production and VIN ranges:
  • 2007 CX-7 vehicles built from February 14, 2006 through August 1, 2006
    • VIN Range: JM3ER29**70100057 - JM3ER29**70128616
  • 2006-2007 MX-5 vehicles built from January 6, 2006 through August 2, 2006
    • VIN Range: JM1NC**F*60111723 - JM1NC**F*70125568
  • 2006-2007 RX-8 vehicles built from January 7, 2006 through August 2, 2006
    • VIN Range: JM1FE173*60200012 - JM1FE173*70208462
  • If the vehicle is within the above Production and VIN ranges, proceed to Step 2.
  • If the vehicle is not within the above Production and VIN ranges, return the vehicle to the customer or inventory.
2. Perform a Warranty Vehicle Inquiry using your eMDCS System and inspect the vehicle for a Campaign Label MSP13 attached to the vehicles bulkhead. Refer to eMDCS System - Warranty Vehicle Inquiry Results table below. NOTE: Verify the campaign number as the vehicle may have multiple labels.
If eMDCS displays:
Campaign Label is:
Action Required:
"Campaign: MSP13 Open"
Present
Contact the Mazda Corporate Dealer Assistance Group at (877) 727-6626 to update vehicle history
Not present
Proceed to "REPAIR PROCEDURE"
"Campaign: MSP13 Closed"
Present
Return vehicle to inventory or customer
Not present
Complete a label and apply it to vehicles bulkhead
"Campaign: MSP13 Open" or "Closed" is not displayed
Does not apply
Campaign does not apply to this vehicle. Return the vehicle to inventory or customer
REPAIR PROCEDURE
1. Verify customer concern.​
2. Replace fuel filler cap with a modified one.​
3. Fill out a blue "Campaign Label" (9999-95-065A-05) with the Campaign No: "MSP13", your dealer code, todays date, and affix it to the vehicles bulkhead.
4. Verify repair.​
5. Return the vehicle to the customer.​
PART(S) INFORMATION
Part Number
Description
Qty.
Notes
FEY2-42-250
Fuel Filler Cap
1
WARRANTY INFORMATION
NOTE:
  • This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
  • Repairs performed outside the New Vehicle Limited Warranty will require DCSM or DSA authorization.
  • Additional diagnostic time cannot be claimed for this repair.
Warranty Type
A
Symptom Code
99
Damage Code
99
Process Number
A0685A
Part Number Main Cause
FEY2-42-250
Quantity
1
Operation Number / Labor Hours
XXB493RX / 0.2 Hrs.
Thanks I got my CX-7 on Dec 28th and 3 days and 200 miles my CEL came on and this is what it was so they replaced my gas cap and did a few other software updates that had codes as well.
Thanks,
Shawn
I got mine dec 28th as well and has 277 miles on it. I haven't seen any warnings yet on the dashboard but I was already aware of this issue so when I had a fill-up, i made sure I closed it tight. I am still having it inspected when I bring "The Beast" for a quality care inspection. Thanks for the heads-up
I asked for the new gas cap before taking delivery (picked it up the end of November)
16500 miles on mine right now and now gas cap issue and no hesitation issue , but i did flashed and i feel the big difference now!!
gas cap replaced
I got mine replaced at about 2700 miles when I got the light. They had just gotten a batch of the new caps in and said that, though it wasn't technically a recall issue at the time, they had been directed to replace them anytime somebody brought their car in with the problem.
