well my msp is fuel cuttin in second thru fifth gear, it does it when the rpm's get around 3k with the throttle pressed a little harder then granny drive style. i can also hear the turbo spool up, it pretty loud. and when i let off the gas it sounds like i have a ssqv blow off valve! the motor also has a vlve tap noise at idle that is louder then normal!! i am just lookin for the best answer to fix all this. and also if you guys think that i might still have warranty on the car? i also have a video of the valve noise!
