FS: TRZ TMIC W/ Forge BPV Kit
Status
Not open for further replies.
Is it still for sale? If so, will it work with PG tip + inlet and SU BOV?
the intercooler doesn't even have anything to do with the intake or turbo inlet ...so yes it should work for that...if ur SU BOV/BPV has the same flange as the stock BPV or a FORGE BPV then yes it will work...
alright man, Do I HAVE to cut up my under the hood parts to make this ugly sucker fit? Looks like a bad ass intercooler!
i would recommend doing so it's such a big (3" cold pipe) cold pipe....the previous owner cut up the underside of the hood so i am not sure if it would fit if you didn't ....but take a look at the coldside pipe of the
TRZ tmic and take a look at the coldside pipe of an ets...and tell me which one is going to flow way ******* better...
probably the one that doesn't use the stock cold pipe
http://carphotos.cardomain.com/ride_images/3/2262/1561/30653280006_large.jpg
alright man two questions 1. cutting out the air ducts stops the diversion of air directed onto the intercooler which can't be good for heatsoak and the intercooler running correctly. That's why the air ducts are there right? 2. will our stuck hosing and connections work with the new position of of the BPV on the cold pipe?? I'm going to be installing a Synapse BPV running Recirc and it looks like its on the wrong side of the pipe and harder to access with the tubing??? Thanks
Status
