FS: Hatchback STEALTHBOX and JL Audio Sub
Status
Not open for further replies.
soilsample
2007 Mz3 Hatch 2.3l Sport
FS: Hatchback STEALTHBOX and JL Audio Sub Sold Please LOCK!
Hello all!
I have a good condition Hatchback Stealth Box for sale. The box fits into the Jack cubby hole.
Ive been using this sub/box since January and have enjoyed it. Very good sound considering that it takes up NO SPACE in the trunk.
Sub is a JL Audio 8w0-4
Specs:
# Nominal Diameter: 8 inches (200 mm)
# Continuous Power Handling: 75 Watts
# Voice Coil: 1.25" diameter, 4-layer, Kapton former
# Available Configurations: 4 ohm (Single Voice Coil)
# Xmax (one-way, linear): 0.27"-0.29" (6.8-7.4 mm) depending on specific model
# Sealed Enclosure Range: 0.30-0.60 cu.ft. (8.5-17.0 liters)
# Ported Enclosure Range: 0.60-1.00 cu.ft. (17.0-28.3 liters)
# VRC" Technology: YES
Selling the sub and the Box for $160 shipped inside USA.
Reasonable offers will be considered!
The box has been modified to use 2 bolts. Both bolts are included and fit perfectly. The bolt holes are enlarged so that you can get the bolt into the nut that is already inside your trunk. I have washers to cover the enlarged holes, I used some silicone to seal around the bolt/washers after I installed to prevent air leakage.
In interest of FULL DISCLOSURE:
The sub has a VERY SMALL scrape on the flexible foam suspension. This is only a scrape, not a hole or a tear. It does NOT go all the way through the foam. I threw my umbrella into the trunk and it scraped the foam...... THIS IS NOT A SCREWDRIVER PUNCH HOLE!!!!!!!
Did this set up create any vibration or rattles in or around the jack cubby hole? or did you line the jack cubby hole with dynamat or something similer?
it would really depend on how loud you play the sub. It would not hurt to put some deadener on the outter metal skin. I have an 8" stealth box and I can rattle the cargo area cover, other interior panels, license plate, etc., without much effort if I want to. Just make sure everything is snug in there before you install one and should be good to go for awhile unless you play it loug
Status
