FS: Cobb AP AccessPort for MS3 - sold
Status
Not open for further replies.
ilikemymsp
Mazdaspeed Protege
SOLD!
Money order only and only 5 posts? Sounds sketch. Buyer beware.
Asking for a money order only is a perfectly valid request when the price of the item is relatively high. If I wanted to scam anyone, I wouldn't have offered pick-up too. Think what you want, the buyer will receive their AP.
It appears to depend on the car. My car in particular shows low fuel pressure at full boost on the 103 maps.
so to run 103 maps, one has to upgrade fuel pump?
im decently modded and when i tried to run the stage2 103 map for my car te fuel pump decided to cut out at about 3 psi and half throttle. with the stock map my car runs fine for what it can do. as soon as i get my fuel pump upgrade ill be set to run the 103 stage2 map which my car requires. so with the stage2 tune my car is basically pushing to high numbers for the pump to keep up. if you have a stage1 and run the stage1 103 map for instance you should be just fine with your stock fuel pump. you would be able to tell as soon as you ran a few data logs if you needed any sort of further adjustments.
you probably wouldnt have to upgrade. you couldnt ever say nevebecause you never know. but probably not. id give it a 5% you wu;d have to change it and 95% you wouldnt. thats just speculation. numbers are not actual
Status
