patty AT forge
19psi with no boost controler?That dont sound right.You may have it to tight.We will see what other people think.
Having a valve too tight won't create more boost.
I've gradually raised it from blue to blue with 1 shim, and then 2 shims, and the valve seems to be working fine, no flutter nor surge. Peaked at 19 psi in the sixth gear.
i originally had just the blue spring installed. When i add 1 shim it seems like the "ping" sound is lower now. This happen to anyone? Also just making sure, shim goes first then spring right??
I hate bumping older threads, but rather that start a new one.. I just installed my forge BPV and I have absolutely zero sound. I have the stock airbox and I expected it to be subdued until my cobb intake gets here, but I have zero sound. I cannot tell if the BPV is working right.
again, Stock except the BPV, have tried the Yellow, blue, and blue with a shim.
Is this normal?
Any help would be much appreciated.
It holds boost far better than the stock BPV, you will notice that right off the bat. It does however have a very specific sound to it that some like and some dont. If you are not all over boost it can sound very similar to stock. However, as boost climbs and the BPV recircs it is much louder and sounds (for lack of a better term) clanky. My wife has referred to it as two samarai ratts are under my hood clanking swords together... Go figure.
LMAO... Not sure about that. She is cool with the modding in moderation. So as long as she doesnt see the money missing or the interest rates I am good.
