Forge BPV question? Green Blue or Yellow Spring? No red?
With KN,Test Pipe and ETS 3.25" I had the blue spring + 2 shims, and it holds boost really good. But now it's different because I've got a Piasini reflash, and the old setup on my Forge don't hold as much as it would!
I think with red spring + 1 shim, I've got a little flutter at low boost, but it means that it's the right setup?!
Here some videos:
2th to 3th gear:
http://www.youtube.com/watch?v=elmqdiR_JHc
6th gear:
http://www.youtube.com/watch?v=4Ga8tI_4vpE
What do you think?
how is the pasini flash and where did you get it from.. can you give me a number or link? thanks
This reflash is awesome!! I gained 40hp and 60lb/ft with only this reflash!! I dynoed my car after the reflash and with my all mods I gained 55hp and 75lb/ft (280hp on the wheels). The car is totally different now!!
But I couldn't give you the number or link in US because I live in Switzerland!
Here a link who someone did the reflash:
http://www.mazdas247.com/forum/showthread.php?t=123720398
Subbin' because I think the Forge BPV will be my next mod. Is this mod actually SAFER for the turbo than the stock BPV? Or is it more of a performance from holding boost longer gain?
I think the stock valve was being "safer" bleeding off boost that would probably be easier on the turbo than holding higher boost longer. So I guess its performance because you hold boost longer, went from peak 18 to now 20 and hitting 15 and bleeding off to 11psi to holding between 14-15psi. Thats blue with 2 shims on mine.
Has anyone had any problems with CELs after installing the Forge BPV? I just installed mine today and I drove around for awhile without the Check Engine Light coming up, but after I got gas the light came up.
Nope...check to make sure your gas cap is on properly.
Yea that's what I first thought it was, but I ensured that it was on right and it is. I just noticed that when I turn off the engine, I can hear a noise coming from somewhere under the intercooler. It sounds almost like a computer's processor when it's working to hard, then a couple of clicks, and then it cuts off. Forget to mention the only other mod I have is the CP-E Nano. I might just have to put all the stock stuff back on and take it to the dealer.
Update: I think I found the problem. The gas cap won't come off.
Uhoh....there is a l o n g thread about this on one of these sites.
Good luck!
I finally got it off after reading a post over in the Mazda 5 section, but the check engine light is still on. Could it just be the ECU?
take out the neg terminal on your battery for a few minutes and put it back in. That should reset the CEL unless theres still a problem. Or you can use a dashhawk to read and clear.
So I just came back from Advance Auto to read the CEL. It came back "P2187 System too lean at idle speeds." Could it be that a hose came loose when I installed the BPV?
i dont mean to thread jack or anything, but is there anyway a stiffer spring could be put in the the stock bpv to eliminate the boost leak?
I've just received my Forge BPV in the mail. I just put the blue spring (no shims) in and I am ready to install it! It didn't come with instructions... does anyone have a link to some install instructions? Thanks!
You dont need instructions, its easy.
Remove intercooler cover.
Remove Stock BPV: 2x10mm bolts 2xhose clamps
Install Forge, reverse of above.
I recommend new screw type clamps for hoses as stock dont clamp well on forge.
Reinstall intercooler cover.
Done! Drink Beer.
Yea it was really easy! The clamps are loose but the hoses held tight. I think I'm gonna buy some screw types from Autozone tomorrow.
installed mine today, completed the swap in less than 15 min.
results are pretty solid. seems to build/hold power more effectively.
only 'relevant' comment i would make is that the valve releases pressure so quickly/efficiently compared to the stocker that i experience more engine/drivetrain movement because of the more sudden pressure change. an upgraded motor mount is looking like a must at this point.
I didn't notice additional engine movement but I have the Corksport rear MM inserts. What spring did you use, and did you use any shims?
