Doggone said:Captain
I have read something about the IC pipes being to low on the car is this true?
We installed our kit on a 1.8 automatic.
even if you pulled the pre-cat (used for cold starts) it should be no problem at all passing.
more power and a consistent CEL if you don't relocate the second O2 sensor.
Basically, the two O2 sensors need to have a cat between them. It's okay if that cat is the larger, second one. You will have to weld a new bung plug on the exhaust after the cat in order to do this.
What does MIL stand for?
The only question I have is will this kit work with my auto p5 without any other modifications other than the IC piping?
Keith@FP said:Basically, the two O2 sensors need to have a cat between them. It's okay if that cat is the larger, second one. You will have to weld a new bung plug on the exhaust after the cat in order to do this.
