happy and angry
So I put my summer tires back on my car a few weeks back and last night the weather was fantastic, so I went out to a quiet stretch of freshly paved parkway to play around a bit.
I take my time shifting which is probably why I've never had some of the problems other members of the forums have had getting into 3rd gear under hard acceleration. This doesn't generally bother me because I don't normally care much about working through the gears really quickly. I try to get fully into gear fairly gently before I step on it, generally before a corner into 2nd and then getting on it after I've finished turning or down an on ramp in 3rd. I don't normally drive my car too hard, but when I do I notice a bit of turbo lag between up shifts. I know it's because I'm off throttle when I shift and because I take my time shifting and the turbo spools down because of it, but like I said, this isn't usually a big deal to me.
I wasn't interested in tooling around at high speeds or racing last night, just doing a few launches, short shifting into second, and then trying to flat shift into third to see how much it kills the turbo lag. I tried a few times without success; coming off throttle on an up shift is instinctive after 10 years of driving stick. Feather the clutch into a firm take off in 1st. At around 4,000 rpm clutch in, shift into second and come out on the clutch again when the motor has dropped revs to match vehicle speed going smoothly into gear. Blast up to around 5,000 rpm before going into third. Rinse and repeat three or four times without problems until I finally get my right foot to stay on the gas between 2nd and 3rd.
When I finally manage to stay partly on throttle between gears, it holds revs at about 4,000 before I clutch out into third. I wasn't trying to keep it pegged between gears, having not done this in a while and never in this car, but as I clutch back out I got fully on the throttle again. When it goes into gear, instead of killing turbo lag and getting a noticeable surge into gear, the vehicle accelerates hardly at all and my engine spins up to about 6,500. My clutch was slipping. Badly.
I stop. I smell clutch. I stop horsing around with trying to flat shift my car, drive home, and worry about what might be going on with my car since a lot of people on here seem to have very few problems doing this, and the first time I do it I glaze my clutch.
I've been noticing that my friction point has been getting wider over the last little bit. It used to bite early and bite hard, with a very small range of pedal movement between being out of gear and being in gear. Now it bites early, bites kinda gently, and it feels like the clutch is still partly disengaged until very close to the top of the pedal travel. I don't slip the clutch or do hard launches a lot, I rev match every shift up or down, I don't ride the clutch, and I don't keep the clutch pedal in at a stoplight (IE: sit in neutral clutched out, clutch in and engage first just as the light turns green). I've tracked it once, wasn't going to start taking it to the strip until the spring/summer as I finally start making some mods to the car to help track gains, and generally take it pretty easy with my shifts as explained above. I have 12,000 miles on this car over 17 months of ownership.
Has anyone else had any of these issues? If so, how did you resolve them? Get hard times at the dealership over what they consider a wear component? I've heard of other people having done hundreds of drag runs on the stock tranny without any issues. Having transmission problems after limited hard use and careful shifting in general is a fairly big concern for me, and I'm curious if it's widespread or if I am just an outlier.
