Hi guys,
So first of all I did RTM, and I also did a search about the particular problem I was having with the system on my 2014 CX-5 Touring, and it does appear as though some other folks have had this issue. I just want to clarify whether or not we are talking about two separate system and if they are just confusing me.
Driving into work this morning I got a warning on my dashboard telling me that tire pressure was low, so after I got home from work I let the car sit for about 2 hours with the ambient temperature being around 45 or so and when I checked them all 4 tires were low, around 26psi or so. I brought them all back up to 34psi and hit the reset button to the left of the steering wheel. I thought that would fix the problem but even though the light flashed twice and the beep sounded the same error message popped up telling me that tire pressure was low.
Frustrated, I double checked all the tires and they were all right at 34, so I went into the maintenance menu remembering that I had the reminders set to remind me every 3 months to check the tire pressure. I still had about 12 days left according to the car before I needed to check pressure, but it seemed like some other people were getting the same error message with 10+ days left on the reminder. The warning only went away after I turned off the maintenance reminder and then turned it back on, resetting it to 3 months.
Bottom line, is the system screwy or was it just the reminder I had set myself? Seems odd that it would continue to tell me pressure was low even after I brought them all back up to 34psi.
