Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
ive been experimenting with different sized nozzles for a few years now, if you look on the first page you can see how I rigged 4 nozzles. I changed the fuel rail so that it feeds from both sides. Ive upgraded to a 250psi pump that is designed to handle pure methenol same with all fittings and lines. I run 50/50mix water/meth on low boost, pretty much all meth high boost.
blkzoomzoom is still the king as I cant seem to keep a high boost setup alive long enough to make it to the track.
thanks thats what i was going forhave you made it out to a track in spain? Im sure with your engine power numbers your could embarrass pretty much everyone on the board here lol
Last time i time it with a Dash hawk type device i have which is pretty accurate, I have a 0-150 mph video on streetfire and there according to the little machine car did 0-60 in 4 Seconds Flat, 1/4 mile 11 Seconds Flat. im pretty sure with better tires i could lower the times a little specially in 1/4 mile. Im pretty sure i could be in high 10s in 1/4 with good gripping tires..
