F/s Forge Wga - sold
Status
Not open for further replies.
tru-boost
2007 sunlight silver speed3
Sold.....Sold.....Sold......Sold.......Sold.....
i have an extra one of these just laying around. i did the test fitting for forge and have one that needed some tweaking to fit on my car right now. this one is the final production version and is good as new. i used it for about a week just to test it. i kept the other one knowing most people wouldnt want one that i modified myself. so here it is a basically new forge WGA. this thing will greatly reduce your spool up time compared to the way too soft stock actuator. i am including.... the actuator with blue spring installed, a red spring, and a yellow spring. the actuator also has a high quality silicone hose with a T fitting that will allow this to be used with the stock boost control system. if you run a MBC simply take that piece off. thats how i run mine.
$150 shipped
How hard is this to install?
Its pretty simply actually. Its only 2 bolts that hold it on and a little clip that attches to the WG flapper. I removed the battery box and inlet pipe and it gave me lots of room to work with. I would say a little over an hour to do for a first timer.
Status
