Exhaust Cutout? Good idea?
I have a q-tech that I am trying to sell for $140 shipped and it is brand new in box never been used. It is a 3'' inch cutout.
if i have the 2.5" apexi downpipe + catted mid, where does the cutout go?
^^ I've heard the q-techs are good too, good luck with the sale.. it would be pointless for me to get one because I'd put the cutout after my cat.. I won't go catless, no way no how.
is it possible to put it before the cat? or does the qtec require a catless exhaust system no matter what?
Kansei said:
Yeah I would assume 99% of people would put it before the cat.
Yup, the less restriction you have, the more power you get. For turbo that is, N/A cars have to keep some backpressure.
what does the ignition wire look like?any is there any way of tapping into a wire with out splicing it?Theres two wires that are with the qtec its black and red which is which?
sorry, yesterday was a weather nightmare and I just got off work today, you still need assistance?
there are two blue wires and two red wires for ignition, you want one of the blue wires. You don't want to cut the wire! you want to buy the connections that just splice around the existing wire, no cutting involved. the red qtec wire is your power and black is your ground, just bolt that one to the chassis under the dash somewhere.
first pic is the drop down panel under the steering wheel, self explainitory
second pic is looking up between the steering column and the yellow arrow is the blue wire I want you to use, you can see my tap there. The red arrow is just there to say there is another blue wire towards the back of this bundle.
third pic is where to run the wire to take it to the cutout under the car. this is the driverside firewall grommet. The blue line is the clutch pedal to use for reference, the yellow arrow is the stock msp sub enclosure constant power wire, again for reference, the red circle is circling teh grommet that you are going to push your wire through. You can just force it through with a screw driver or I actually had to pull the grommet into the car and pass a large component through then replaced the grommet, the grey wire is the bundle of wires for my cutout.
Here is a picture of cheep wire splicers that don't require cutting the wire. These will work, but they aren't the greatest ones to get. I get mine from a auto electronics dealer so they are professional grade. This one isn't.
here is a poor, but informative video on popping the blanks out. I hate rapidshare but I used it anyways. click this link http://rapidshare.com/files/1076459/switch_006.avi
click on "FREE", wait for the 30 seconds or whatever, you'll see it counting down, then enter the code on the left usually like three letters/ numbers that are blurry, then click save
that helps alot now I can use this for reference...in the third picture where it says push your wire through what do you mean by that?Is it just a hole thats free I can get to under my car?
