Exhaust Cutout? Good idea?
MSP608 said:
wont an electric cut out give you a CEL??
no. your O2 sensor wont read hardly anything at all since the exhaust will be shooting outside of the car and not into the pipe where the sensor is on. it only throws a cel when too many fumes are pushed through the sensor area.
I just putted a set of non-foulers on the new midpipe and I never saw a cel since the beginning of the summer.
gotcha, that makes sense
I think he meant when the cutout is closed and the fumes are going throught the normal exhaust path.
is true but i still never get a CEL even the few times im running closed.
no, why would you get a CEL from when the exhaust is going where its supposed to. i just figured that if the o2 sensor did get anything itd freak out
yea you would think if you open the exhaust the 02 sensor would read a lean condition and throw a cel......because no exhaust is passing it. Unless the 02 sensor is upstream of the cutout.
Puckpimp71 said:
I just read a post where a guy with the unichip and either SMIC or FMIC gained about 9whp with it open. He had stock cat-back, but bigger mid-pipe... can't remember where the post was, but I think it's worth it. I have the QTP and LOVE it. I keep it closed 99% of the time, but the sound alone it worth the money.
yea that was my car. its unichiped smic. i am running a catless midpipe with stock exhaust. with full exhaust i put down 207 and with it open i put down 218
well i ran mine at stock boost at the track and i ran slower, i think the spool time was longer... but i would bet at higher boost it works better.
what I meant is that when the cutout is closed, at least in my setup (see pictures in the link I posted above), there is no cat before the o2 sensor, thus it could throw a cel. That is why I putted the non-foulers on.
because your cutout would be replacing your first cat (or at least it does in my setup). So when closed you would be missing a cat.
Well i run open s-pipe because the performance is dyno proven, plus i love the way it sounds, loud yes but worth it even more. cops where i live dont care, i just ease the throttle when i see one anyways and its pretty quiet, neways my cel came on when i started running that way for the reason the O2 sensor isnt reading any exhaust gasses at all. The code it throws is 02 not reading. It doesnt make the car run bad at all. in fact my gas milage is higher than most at around 32 intown and ive gotten 41mpg on the highway usually averaging 38-39mpg. Now if you unplug the o2 sensor then yes you will throw a code and the car will run like crap because it will think there is a malfunction in the system causing the o2 not sending a signal back to the ecu.
BoOsTiN said:
alot of DSM guys use these, I wouldn't unless you wanted it open a lot. It opens when you go into boost. having an electronic controller gives you a lot more freedom to have it loud or quite when you want. I perfer the sound of the cutout under small loads anyways, but if it opened every time I went to boost, I dont know how long I coul take that. Plus that would draw a lot of unwanted attention.
you know i was thinking of using an electronic cutout to utilize an open wastegate dump tube. with the cutout closed, the wastegate would dump back into the exhaust system. with it open, it would go to atmosphere.
gosh, makes me wanna have this
i think my next mod, after getting the hard pipes done properly, is an exhaust cut off, i think is cheaper than expending 600$ for a full racing exhaust...and that way i can put a muffler back in my car and have a quiet baby when not racing
:-) If I can ever make it to a meet, I'll be happy to show you mine. I love it.
so does the cut out go right after the cat? and if so does this mean you can buy a mid-pipe from somewhere and put the cut-out on right after it?
if that is possible to me that is similiar to buying a 3" exhaust for almost half the price
