Engine Mount OK?
ki.forum
2003 Mazda Protege ES
My protege is making a clunk noise when hit bumps/pot holes. The sound looks like located in the passenger side. I suspect the strut mount but haven't checked it yet. I went to see the engine mount and took a picture of it. I cannot tell if it is the cause of the problem or not. I need you guys to check.
Thanks
Looks okay to me.when I replaced mine all the rubber was ripped and just sitting inside that.
Your noise is more than likely a worn/broken sway bar link on the passenger side. replace them in pairs.. That motor mount looks good and would not replace it.
