It is controversial on whether a MAF or MAP is easier to tune...To my understanding, a MAF sensor can be tuned more accurately when accompanied with a air temp sensor...MAP sensors are easier with boosted situations because the pressure is "read" directly in the intake manifold and outputed to the ECU...the ECU can "see" what boost the engine is being thrown, and incorporate fuel...It basically makes the fuel maps pretty logical and easy to understand...you can tune it for different amounts of boost at different loads and engine speeds...It is a little trickier for that with a MAF...Someone please clear this up though, I may have missed some things...
Also, with proteges: when someone mentions a MAP sensor as an "upgrade", that is a little misleading...The new sensor mostly is needed for output problems of the stock air meter (which is a MAF)...Some ECU upgrades puke when they are fed our MAF's voltage numbers...So they "upgrade" to a MAP, which are cheaper and easier to source, as well as generally easier to deal with for boosted apps...But don't look at like you will be getting more power with a MAP, the difference would not really be noticable...It mostly just makes life easier for turbocharged setups...You generally do not see MAP's being run on NA setups, even though it will still work...just some argue MAPs are not as accurate...
EDIT: Do not regard any of this...I was wrong on some parts, read Perfworks replies below!
