Installshield 2 said:
Alright now I have a question...According to your link Nick, Open Loop is referred to as a condition where only the maps are used...also that it is only used a WOT, and offers no compensation from other sensors (such as air temp, coolant/ engine temp) other than those required for triggering (engine postion sensors and load sensors)...which overall makes it not very adaptive to adverse conditions...
So here is the question...does a Protege actually use open loop only at WOT, like the fabled myth from years ago? I originally thought this was the case: Open loop at WOT, normal running at loaded partial throttle apps, and closed loop for idle and light load cruising...But I was defeated on that front, and was told that there was two modes only ...Open and Closed...used on a protege's ECU...
so is that link just referring to normal running and Open loop running as two seperate things, although they generally can be regarded as the same...I have heard some EMS manufacturers claim that mapped Open loop will use other sensors to detect abnormal conditions; does not use the O2 lamda sensor; and is not only at WOT, which that link claims otherwise...and those reps for the EMS's was one of the reasons I too realized that closed loop was not always used at every partial throttle application...and Open loop not only at WOT...
This may simply be a mix up of definitions, but can you clarify it at all?
Well i think i understand what your saying...
Just kidding. LOL.
EVERY single car and every single EMS is mapped differently.
Mostly what i mean is that depending on the application the ecu (ems) will have two different modes of operation ( open and closed loop) BUT different or various drive cycles. You can say drive cycles are another name for a "correctional or supplimental" maps that are used to fuel and spark the spark plug in the engine. These would include cold start, hot start, partial throttle, WOT , cruise condition and many more. Some cars will have up to and not limited to 12-14 different drive cycles. Those specific drive cycles will use the appropriate map for fuel and ignition lead.
Now the protege ECU is very complex. What i mean by complex is it is very adaptive. The EECV ecu is very advanced in comparison to some earlier model ecu's. It will stay in closed loop for as long as it can. In most cases (which some others can confirm also) the ecu will go into open loop "mapping" over 4550 rpm, very heavy load ( such is the case when in third gear and low rpm ) intial start up and cold start.
For example some chryslers like the SRT4 or mitsu EVO will go into open loop over 30% throttle regardless of rpm. Every application will differ.
Now when in open loop the only sensor that is disregarded ( for the most part) is the O2 sensor. Only because it just doesnt react fast enough. The ecu will most likely have latency in its reaction time also and cant adapt safely enough to rely soley on its input.
The "loop" is broken. What i mean by that is that the network of sensors are now like a peg leg. It doesnt have its most important sensor there to confirm it is fueling correctly. It is relying solely on look up tables to base ignition and fuel enrichment. (Lets not forget the knock sensor) Those look up tables still "confirm" the air temp and engine temp. They are at that point learned to be a constant because the majority of the time when you are in open loop it is after the ECU has had time to learn the previous drive cycles and infer that you are in the same enviroment. It will look mostly at the load (TPS and MAF in the protege case) and engine speed (RPM via our crank sensor) to determine how much fuel and ignition lead is needed. THAT is why some piggy backs that are on the market are succesfull in helping to produce some marginal gains in power. They will massage the airflow or load readings in open loop. You can either "trick" the ecu into thinking it is a different load value by increasing the output from the TPS. Or increasing and decreasing the airflow output values from the MAF. On many vehicles the partial throttle mapping is quite good. It is up top and around or higher than 50% throttle that it is basically "generic". That being said it is easy to say that you can fine tune your existing fueling map by manipulating the signal to the ecu. The MAF signal may be used to vary the fueling in open loop. That doesnt mean that it cant be done in closed loop. It just means that it will be overruled by the O2 in cruise situations or any closed loop operating cycle.
Again there are many things to do to get the optimal tune. For optimal seetings that will hold, on todays ECU's you need to be able to control the entire fuel and ignition spectrum without any interuption from the stock ecu.
I can go into further detail if you like just ask away.
I can also get into how changing various signal outputs will and can put you in "harms way" if you are not careful with the adjustment you alot.
