engine management
Installshield 2 said:
It is controversial on whether a MAF or MAP is easier to tune...To my understanding, a MAF sensor can be tuned more accurately when accompanied with a air temp sensor...MAP sensors are easier with boosted situations because the pressure is "read" directly in the intake manifold and outputed to the ECU...the ECU can "see" what boost the engine is being thrown, and incorporate fuel...It basically makes the fuel maps pretty logical and easy to understand...you can tune it for different amounts of boost at different loads and engine speeds...It is a little trickier for that with a MAF...Someone please clear this up though, I may have missed some things...
Also, with proteges: when someone mentions a MAP sensor as an "upgrade", that is a little misleading...The new sensor mostly is needed for output problems of the stock air meter (which is a MAF)...Some ECU upgrades puke when they are fed our MAF's voltage numbers...So they "upgrade" to a MAP, which are cheaper and easier to source, as well as generally easier to deal with for boosted apps...But don't look at like you will be getting more power with a MAP, the difference would not really be noticable...It mostly just makes life easier for turbocharged setups...You generally do not see MAP's being run on NA setups, even though it will still work...just some argue MAPs are not as accurate...
What a debate this is. MAF or MAP.
They both have good and bad characteristics. As they relate to engine management as a whole though, a map sensor far excedes the performance value.
Lets go thru some things here.
MAP - Manifold Absolute Pressure. Sometimes the name can be misleading. Many if not all Map sensors made today measure pressure in the intake manifold along with baro. They can compensate for altitude changes and thus fuel the motor effectively in any enviroment.
MAF - Mass Air Flow. MANY MANY kinds still exist. Mainly only two that can be useful for our conversation. Frequency and hotwire. I think the article I have linked to earlier has already cleared up some of the basic functions.
But the most important part to any of these will be air temp. When an air temp sensor is incorporated in either a MAF or MAP system it is the most important integral feature for the system. That will give you air density correction.
You see the MAP basically is an assumption of load thru preprogrammed maps in the ecu used for fueling. Its scaling and resolution are basically fixed. Some say a guessimate. Somewhat true but not really. The vehicle tuned with a map sensor will already "know" the proper fueling requirement based on its load output as it is preprogrammed specifically FOR the mods and vehicle being tuned. It "assumes" airflow by the way it was scaled in its original mapping. Usually any drastic changes made to the constant airflow thru the motor above the "bar" it recognizes goes thru undetected. Thus creating a state of fuel enrichment that is basically added by guessing. This is old though. Those days are long gone with the addition of airtemp sensors, technology, enviromental control chambers and rescaled ecu's. You can make any change you want now adays and basically have the ecu reflashed to your specific needs. Almost every manufacturer that i know that uses MAP has this offering.
Now MAF.
It directly measures the airflow "induced" into the motor. I say induce because 99 % of the vehicles out there whether FI or NA pull air thru the sensor. Very rarely will you see the MAF blown thru. It is sensitive and directional. Damage can occcur along with false output readings. This system is great for economy along with the O2 feedback to account for every molecule of air. (NOT OXYGEN) There is a difference. Even when going FI it can compensate to a point. That is where it is a little more acceptable for low boost applications. (stock unit) You can use the resolution it provides to scale your fuel map accordingly and sometimes automatically. But it like the MAP has its limitations. It is scaled for the particular application and any airflow that it cannot read accurately will go by undetected. That is to say if it doesn't create a restriction first. MAF sensors in the tract of a FI setup is a restriction to airflow. Yes you can get a new larger MAF made up and scaled for the car but so can you a MAP. One difference being that in most acses the new MAF will need to be controlled. Either by a new control module (piggy) or reflashed ECU. The difference really is that with a map you KNOW when boost comes in (or boost threshold is met). Period.
Anyone with any credible tuning experience will tell you that. A MAF sensors' resolution FALLS when increasing the capacity. You are still using a small 16 x 16 map and thus cramming in more load without dispensing the duties to more load sites for adjustment.
A map sensor will measure the amount of pressure up against the valve rather than what the engine MAY be ingesting with the MAF value. It gives you an idea of what is really going on AFTER the TB and in the runners. It allows you to tune for boost specifically. The resolution you get when using a MAP sensor for boost is unsurpassed. From 14.7 atmospheres to 30 psi of boost pressure it will allow the enduser to program the EXACT amount of fuel and ignition needed to get the engine running to peak efficiency. The correction alotted for airtemp thru the AIT sensor helps produce an accurate A/F ratio for a given density of oxygen in the mixture. MAP sensors differentiate Boost from atmospheric pressure. This allows you to tune more accurately. Now for NA any one of these sensors will work very well. Not one better than another. If both are TUNED properly you should see little difference if any. Only airflow restriction will cause a variable.
Well I tried with the limited time I had to help a little . I can go into more detail if need be later.
Also Andy, you are right about the BOV issue...Most mount the BOV as close to the TB as possible, which is after the MAF...and you can run into stalling issues...Some have tried mounting the BOV before the MAF, but you run into "bottoming out" the MAF by air surging backwards from the TB to escape...which causes erratic MAF readings, and drivability issues...
So in general a BOV with a MAF sensor is difficult.. with a MAP sensor you have pretty much no problems...an optional setup for an air metered car is a hybrid BOV which both vents air and recirculates it into the intake track...And that is mostly for the BOV sound, but helps with the other issues...
AHH BOV . It sounds so nice doesnt it. I like it now with mine being tuned with a MAP. (30 psi before 4000 rpm)
It can be vented but idealy i like to recirculate it. It keeps the turbo preloaded between shifts and IMHO it works better in that capacity for the street. Some have varying opinions on this and i really dont want to start an arguement. But generally you will use a BOV for MAP and Bypass or recirculate the pressure when using MAF. You can however tune the MAF to accept an Open valve with decelleration correction maps via piggy or standalone.
akhilleus said:
It is also one of the few ecu mods that have been reliably proven, as of recently on paulmp3's car. This system also uses a wideband o2 sensor.
the mpi tuner doesnt use a wideband o2.. i just have a wideband o2 sensor with display to get accurate AFR readings.. the mpi tuner uses the stock narrow band o2.
s*** Nick, that was amazing...I knew I didn't fully understand the differences and advantages between the two sensors...Thank you for clearing that up:D
Hey if your not busy give me a call i have something to ask you.
Damn thread jack sorry.:D
well here's hoping you say...
connect this this and this wire to these point, now wire those up to a usb cable and connect to a computer. then you can use this program to totally change the maps in your ecu
somehow i doubt it though :(
That's what I need. When I close the throttle to partial open after boosting I go pig rich (11-12 on the WB). It bucks and the only workaround is to push in the clutch or reopen the throttle (not good if you're decelerating into a curve). How do you get deceleration correction maps?
What kind of piggy are you using? If you want to pm me do so.
perfworks said:
Hey bud,
The ecu we are working on is completely plug and play. You remove your ecu and plug this one in. Very simple. No hacking of the harness. All your stock sensors. Or replace your restrictive MAF and convert to MAP. No extra injectors. Just use your stock or larger. (we recommend 550cc for forced induction and 440cc for N/A with high compression pistons and appropriate cams). IT will control everything. Ignition timing an fuel. We will tune the ecu for the specific application. We are also thinking about a self tune feature with a WB O2 so that it will keep you out of "trouble". Your stock ecu will still be used for everyday functions like cruise control, Tach, speedo, AC switching etc. I am trying to make this as user friendly as possible. So all that needs to be done is physically pluging this bad boy in. Hopefully by the end of January they should be ready to market.
I wont comment on the VERY well known company we are going to be using because we actually have 3 company's that we are concidering. Whoever decides to give us the best support we are shooting for.
Ask away on any questions you may have. I'll try to answer anything i can.
:eek: i want one!
perfworks said:
Hey bud,
In the second sentence you say that you "remove your ecu and plug this one in". But I thought this is a piggyback, so don't you need the original ecu as well? You do mention that "Your stock ecu will still be used for everyday functions like cruise control, Tach, speedo, AC switching etc." Am I missing something?
No this is a plug and play Engine Management System. The stock ecu is used for other functions such as your various output controls. The AC switching, Tach, and speedo.
Where you are getting confused is that BOTH ECU will be used. They will both plug in without any cutting or splicing. We have all the adapter harnesses you need to run them both in parallel. One controls the engine managent properties of Fuel and ignition and the other the outputs for display funtions
Will this ECU work with stock injectors, I have done some modifications on the engine ie cams and adj cam gears
It will work with ANY sensor or output device.
Yes it will control any injector you want. SPECIFICALLY duty cycle. Not thru airflow like piggybacks do.
