SallySpeed3
- GT Mazdaspeed3, Cosmic Blue
Ok I know this topic has been talked about, but I'm posting this because I feel like its unique to other similar threads. I have been monitoring knock for the last few days because I've put at least 25k on my current Denso plugs and just found out you should be replacing them every 15k, not something I realized. So anyway, I get the normal glip of "knock" while shifting which I know is normal and not really knock. I also will get the occasional reading of 1 then .7 then .3 while cruising which I know is just the ECU adjusting for better mpgs.
But what has been scaring me as I have been monitoring I notice that when accelerating and then backing off the gas (not letting off completely, just applying less pressure) I'll get readings sometimes up to 5, 6 or 7. They usually will go away after a second or two, but today while driving I noticed it jump up to 7 as I let off the gas and then fell down to zero in increments of .3, so 7, 6.7, 6.4, etc. This seems bizarre to me. While flooring it I only get .35 or .7 which I have been told isn't much to worry about. Any input is appreciated.
