Engine grounding points?
reply to the grounding
barod60 said:
will grounding help the hiccup felt when you stab the throttle on the atx
I'm not sure if it helps the auto tranny. But I know for a fact it did help my throttle response. I would hit the pedal and it would take a full second to respond now its faster response but no noticable hp gains
goldwing2000 said:
Or maybe not. From what I've found so far, it's a total scam. Still researching, though.
http://www.automotiveforums.com/t149691.html
If you check out some other websites out there, people have had good experiences with the Hyper Voltage System by Sun Automotive. It seems like a similar system, more info here:
http://www.matrixowners.com/modules.php?name=Forums&file=viewtopic&t=20054&highlight=mr
http://www.matrixowners.com/modules.php?name=Forums&file=viewtopic&t=26948&highlight=hyper+voltage
http://www.matrixowners.com/modules.php?name=Forums&file=viewtopic&t=22611&highlight=hyper+voltage
I plan on getting one eventually ... every little bit helps.
To go back on topic, if someone could post the points/lengths of wire they used for grounding that would also be helpful. Thanks :D (nana)
i wouldnt really worry about the hp gains. i would be more concerned about efficiency of the ground kit. ive seen the some point maps on the forum though... i think there is one on the for sale thread:1st ground kit i think... ill look for it.
