Last night my electrical system went crazy it's like it had a mind of it's own. I pulled the codes and there were a ton. For example idle too lean, bad cam censor? timing jumped, short circuit, maf censor problem and a few others I can't recall. My dash lights would dim then go bright my headlights would go on and off and my parking brake light was on without the brake being engaged. My car also hesitates then goes hesitates and goes like it's bad gas but it's got to have something to do with the electrical system. I got an oil change that day and washed my car the only thing that I noticed was that my driver side headlight had water in it. My car was in idle for about 30 to 45 minutes also my wife said. The only thing working correctly is the boost gauge so I figured if it was the gauge that caused this it would be having issue also but it's not. It's all stock other than a Cobb sri, Forge bpv and Cobb tip. It's like everything that runs through the steering column is shorted out. If anybody has had any similar issues I would really appreciate some feed back.
