Electric Parking Brake Issues
My 2019 CX5 is having an issue with the EPB. Some initial context, when I first bought the car used in 2022, there was an issue with the EPB where it wouldn't disengage. Took it to a dealership and they replaced the EPB motors on both sides.
Just recently I went to do the brake pads and rotors on all tires myself. Before starting on the rear brakes I put it in maintenance mode, got everything undone, went to compress the piston back in and it wouldn't compress in all the way so I couldn't get it over the new pads. So I put it back together with the old pads, took it out of maintenance mode then put it back into maintenance mode to hope that maybe it would work itself out. No luck, the piston still wouldn't compress all the way. So with it still in maintenance mode I took the EPB motors off and tried to manually retract the screws. This didn't help at all, the screw was already retracted as far as I could make it go. So then I put everything back together but used 1 new pad and 1 old pad on each side, planning to take it to a mechanic or do more research before coming back to it and trying again. Then when I took it out of maintenance mode, I heard the motors actuate but then got a parking brake error light and I couldn't use it anymore. It won't go into maintenance mode or anything.
So then I got an ELM327 to USB and downloaded Forscan so I could read the codes and reset them. I have C112A:77 and U3000 DTCs on and they won't reset. I tried resetting the EPB module with Forscan and I hear the motors but the codes don't go away.
So now I replaced the calipers and with new calipers I had no issues getting the new brake pads on. Bled the brakes/did a brake flush because it was overdue (the brake still has a lot of travel but I figure I might just need to bleed it again maybe after driving on a bumpy road to get the ABS to cycle some). Pumped the brakes, turned on the car and still the issues. Tried resetting the DTCs in Forscan with no luck, tried resetting the EPB module in Forscan and still no luck.
My battery was on its way out so I went ahead and replaced it. Checked the connectors and they all look good and aren't loose, checked the fuses for the left and right motors and neither are blown.
Before anyone asks, I never tried screwing in the piston. As far as I am aware I did pretty much everything according to the books.
I'm basically all out of ideas but I can't even really get it to a mechanic because despite the parking brake not being physically actuated, the car thinks it is and it beeps very loudly when I try to drive it.
Does anyone have any ideas at all on anything else to try? Is there some sort of other better scan tool I need to run an EPB calibration or something?
How did you end up resolving this? I might do brakes in the future and it would be most useful to get your insights as to what caused the issues you faced.
Also I am considering getting Forscan and the OBD2 adaptor. Would the software be able to clear DTCs on the EPB module?
