I had never seen anyone post this detail about Eibach springs, so I thought I would share, ...
What shocks or struts should I use with an Eibach Pro-Kit? Index
Eibach Pro-Kits are designed to work with original equipment shocks and struts provided they are in good working condition.
Aftermarket performance shocks and struts will increase the overall performance of your suspension and are also recommended for use with Eibach Pro-Kits. Pro-Damper - valved by Eibach, is the newly established line of Eibach performance dampers. The Eibach Pro-Damper is the ultimate match for the Pro-Kit as it is the only damper line which is valved to work in unison with the Pro-Kit characteristic.
Off their website.
Off their website.
