Eibach Springs Installed *Pics Included*
Armyguy1104
06 MS6 GT
You've gotta have some before pics in there right as some of those still have the huge gap.
Gettin' mine put on this weekend (pro kit).
Yea its the Pro Kit. Good thing I didnt lower it any more as I already bottom out on some speed bumps especially on base.
Should've explained I guess. Starting with the first, every other one is with the springs installed. The ones in between are to show the difference and are from about 8 months ago or so. I also removed the film from the headlights as it blocked out way too much light.
I just finsihed installing my fronts ... will do the rears tomorrow. I took a measurement before and I'll take one after 4-5 days after it settles to see what the diff is.
Re:
Armyguy1104 said:
I like the drop. I wanna do mine but scared of everything else you have to do when you drop your car. Did you have to get new shocks? Did it mess your alignment up? Did u have to do any work to cambers?(idhitit) Let me know. Thanks, Jorge Miami,Fl.
Its not that drastic of a drop so I havent changed anything else out yet. Eventually I will changed what I have to to make it right though, Im not doing anymore work while I am up here in MD since they charge an arm and a leg for labor. I'll wait till I get back home in FL and have some of the shops there I've used do the other work, including adding the CP-E DP and Exhaust. I have the magnaflow now but want something to produce gains if at all possible. The alignment is off alittle, it pulls to the right while I am on the highway if you release the steering wheel, hardly noticeable otherwise. Tried to get that fixed yesterday but the wait was over two hours so i'll go back. Not sure what you mean by have to mess with the calipers? They have nothing to do with a drop?
Re:
I meant the Cambers. Sorry(gun)
Thanks, Yea they do make the Sportline Kit which is a 2" drop in the front. I already have to go really slow over speed bumps and such, the car will bottom out after the front wheels come off the speed bumps if you go to fast.
I have the sportlines. The drop is low which i like a lot more than the other drops ive seen. I've only bottomed once.
Looks good man, Ive been contemplating which springs I should get, Ive had Eibach prokit before on my old 3gen eclipse loved the ride and drop. Ive just heard the ride is harsh with them on. I cant decide between these or H&R's. let me know how the ride is.
