ECU Oxygen sensor wire ????
LV Tunerz
07 MS6 GT
can someone please tell me where the oxygen sensor is on the Speed6 . im installing my turbo timer and cant find that wire . ECU Help please
The MS6 uses 2 oxygen sensors: One right after the turbo, which is a wideband, which I recommend you DO NOT tap into at all. There is a second O2 sensor, located after the first cat, but before the second cat. This is a normal narrow-band O2 sensor, that if you had to tap into, I would recommend this one.
Just buy an aftermarket wideband 02 sensor and use the 0-5VDC output for the turbo timer. From the sounds of it, you plan on doing serious modding, and the A/F ratio gauge should be your 3rd modificaton after a boost gauge, and intake.
Granted, I never installed a turbo timer, but what does the oxygen sensor wire have to do with a turbo timer?
Fill me in ...
what it is , is that i sell aftermarket performance parts here in Las Vegas .And my distributor sent me new a'pexi 4 in 1 turbo timers for free and im trying to hook one up . What this turbo timer does is ...
1) Automatic calculation of the necessary amount of after idling time
2) Displays A/F Ratio
3) Displays Battery Voltage
4) Displays O2 Sensor Voltage
5) Diplays RICH or LEAN via 2 LED's
6) Warns of extremely low battery voltage
They come in a clear casing also which i think is sick . So thats what im working with and yes i do plan on throwing down massive power
You ould hook it up to the rear O2, but it will always read lean.. You will damage the ion pump in the primary O2 if you try and tap anything too it.
Hope this helps:
