Dust Leaking into Interior thru Rear Door?
riZen
Hello,
Is there a common issue with dust leaking thru the rear doors into the lower interior of the CX-5? It seems to be a common issue in the CX-70/CX-90 forums but I wonder if they have a similar design flaw where the rear door overlaps into wheel well, unlike the CX-5 the wheel well is enclosed and separated from the door. Otherwise if the same issue happens with the CX-5 then I wonder if it's the seal at the bottom of the door where it overlaps the rocker panel on all models.
I don't know that it's infiltration, but my CX-5s always accumulate a lot of dust. The only source of fibers in my car should be the carpeting, so that's what I thought it was.
Upvote 0
some dust yes, but nothing to worry about. Almost any car has something at those locations.
unless the door or seals were changed of course.
Do you have actual problem or just wondering?
Upvote 0
