I'm just worried that anything you put on will be more restrictive than the stock exhaust, causing you to lose power. Not sure though...sorry I can't help out moreI would suggest going to their forum and asking if the MS3 exhaust is a direct bolt-in replacement for their exhaust...that should give you your answer. If it's a direct fit to go from MS3 to Mazda3 then the inverse should also be true.
