If the tips were 1" smaller, I think it'd look REALLY good.
I agree fully man. But it still looks nice. I want to hear it too........
holy wow. this looks like a custom kit from the back, but a professional kit from the looks of the actual fitment and piping. unreal. looks like i have a custom job for the spring. cant say it will be as show like though. lol.
i like the big tips...it fills out the slots very well.
sometimes with exhausts its hard to get everythign perfect. i think its a pretty bang up job though. def the best exhaust ive seen on a 3
the following cars are now considered "ghey":
s2000
mazdaspeed6
srt4 neon
audi tt
sti
evo
lotus elise
Do you lose power because of less backpressure even if you have a high flow cat in the downpipe?
single is less restrictive on inline engines by definition - you don't introduce additional resistance in the point where you do fork.so i wont lose any power from the dual? then why do most turbocharged vehicles switch to a single exhaust?
when the exhaust gets pushed out of the cylinder by the piston it needs some sort of backpressure regardless of being charged or naturally asperated. in an NA applications the exhaust plumbing design along with restrictions like the catalytic converters and muffler create the backpressure. in turbo applications the turbine is the main restriction in the exhaust. superchargers and prochargers are in the same boat as NA when referring to exhaust since they don't use exhaust gasses to charge the inlet air
when you have V configured engines, or if there are 2 separate banks of exhaust, they design the plumbing to help "pull" exhaust away from the combustion chamber through use of exhaust reverberations....ie H or X pipes in some V-8's
in addition, charged engines usually have bigger exhaust valves than intake valves. other way around for NA
^^cosign^^
the quad tips look really good. the single tips look ghey.
either way, dual on 4 banger is ghey rice
i have never seen a car where the exhaust valves are bigger then the intake valves..
