I have my bov t'd into the brake booster.
Thanks for the picture.. but just to be sure.. the check valve is on the left of your T fitting? Thanks again for the info.
Also, my SS AFC should be in this week sometime... Is it safe to put another T into the brake booster for the AFC along with the T for the 2nd BOV?
You run a Dual set-up so you don't have to relocate the MAF. If you run a BOV with the MAF in the stock location the car stalls out if you stop after blowing off. Basically the MAF reads air that is no longer there causing the car to stall. Using a dual set-up fixes the stalling. Or you could run just a BOV and relocate the MAF after it. I have my BOV on the HOT pipe and the MAF on the COLD pipe...No stalling!!!what is the point of running a dual set up? Sorry I just got my car and don't know much about turbos
I think your asking what the whole pipe is called...If so the pipe that goes from the intercooler to the intake manifold is called the COLD PIPE.what is the piece of intercooler pipe that goes to the throttle body - where the BOV is mounted in the first set of pics? I cant afford to get a whole set of hard pipes, but would like to get one for that so I dont have to jerry rig my BOV to my stock plastic piping.
Does anyone think this setup could work on a MS3? Love the greddy type-s vta sound but cant run vta...........
anyone running a dual setup with both bov and bpv on the cold pipe?
