Dexter said:why is it called double clutching?
Double-clutching is usually reserved for those driving trucks or high performance racing cars, but anyone with a manual transmission can perform this simple feat.
For most manual transmission drivers, the act of shifting gears is a straightforward one. First the clutch is depressed, then the shifter is thrown into the next gear, and finally the clutch is released putting the car back into gear. All of this is usually done without thinking, at least after some practice.
But double clutching adds a third step into the mix. The shifter, rather than going straight to the next gear, makes a stop in neutral and then the clutch is released. This is to allow the engine to slow down (or with a tap on the gas, speed up when downshifting) so the transition into the next gear is much more smooth. The driver then depresses the clutch again and completes the shift into the target gear, and finally the clutch is released again, putting the car back into gear. It only takes a split second for the engine speed to match the speed of the gears, so the entire action is done very quickly as a fluid sequence of events.
Most modern cars, however, are equipped with devices called synchronizers that help to synchronize the speed of the gearbox with that of the engine. This effectively eliminates the need for double clutching. Some large trucks on the other hand have so many gears that synchronizers are inefficient, while race cars can squeeze out more power without them, making double clutching a fact of life.
There are times, however, that a normal car driver may want to make use of double clutching. Many manual transmission drivers realize the advantages of downshifting in slippery conditions. Rather than brake and skid, a car with a manual transmission can make use of the engine to slow down - thereby eliminating the possibility of a skid. But even with synchronizers, a driver trying to shift from fifth gear into second could have some trouble. In this case, double clutching by pausing in neutral and giving the engine a little gas to match speeds of the engine and gearbox, can allow such a drastic shift.
Some driving purists maintain that it's still the proper way to shift, and makes for a much smoother ride. It eliminates some of the jumpiness sometimes felt in a manual transmission car, and it decreases the stress on the gearbox. In any case, double clutching a skill worth having in emergency downshift situations, and not very difficult to learn.
toucci said:you disengage and reengage the clutch twice
You have to engage the clutch with the shifter in neutral for it to really be double clutching. This gets the gears inside the gearbox going the correct speed before it is put into gear, the action normally provided by a synchro.Dexter said:i will be in gear...need to slow down/downshift, disengage the clutch, press the brakes, blip the throttle with my heel, and re-engage the clutch.
is that not the same thing or am i missing something?
Dexter said:oh...so for accellerating, though i will press the clutch, rev up, and then downshift.i dunno, it all seems to accomplish the same thing
lospez54 said:how do you heel toe shift?
....toucci said:...It's often used for downshifts and is often combined with a heel-toe movement to downshift while braking, using the toe of your right foot to hold the brake and your heel to blip the throttle.
BrianG said:I've read this before and was wondering something, but didn't want to sound like an idiot. Instead of engaging/disengaging the clutch twice, why not simply hold the clutch in and then rev the engine a little to bring the rpms up before letting out the clutch? What purpose does the "pausing in neutral while you let go and push in the clutch in again" serve? What is the difference between that and just holding the clutch in while you rev up or whatever?
I did a little Google-ing and couldn't find a quick answer to this point.
_____toucci said:the only difference is with double clutching you match the revs of the entire drivetrain, instead of leaving the part between the clutch and transmission freewheeling.
The clutch disconnects the engine from the transmission. So if you want to get your gears set to the correct speed before popping into gear, then you gotta engage the clutch in neutral and set the engine rpm.BrianG said:I've read this before and was wondering something, but didn't want to sound like an idiot. Instead of engaging/disengaging the clutch twice, why not simply hold the clutch in and then rev the engine a little to bring the rpms up before letting out the clutch? What purpose does the "pausing in neutral while you let go and push in the clutch in again" serve? What is the difference between that and just holding the clutch in while you rev up or whatever?
