80 LB-FT isn't quite as tight as you might think. But it is the right amount. As mentioned earlier it is important to check them about 10-20 miles after you have had to remove your wheels. Sometimes they will come loose a little and can warp your rotors or even worse you can lose a wheel. For me the best reason for torquing them is for the brakes. They will last a lot longer and since they are constantly heating and cooling you don't want them to warp because of the lugs being uneven. You can even bend your wheels by not under or over tightening your lugs. It is just a good general practice and the reason why I get over 80k miles on a set of rotors. Well with Hondas anyway. Only had Mazdas for a little over a year so will have to see with these cars.whitey4311 said:I just did a rotation last night and have no torque wrench but I though I had them tight enough and the neghibor works on trucks he said they were too loose. He sort of pushed on them a bit more and they did budge so they werent that tight I guess.
I will buy a wrench but I noticed that at only 5k my fronts look pretty freaking worn compared to the backs. I also talked to the neighbor and he said since the out side edges were more worn that the PSI was low and that I should up them. So I out 42psi front and 40psi rear to get the tire to ride more center and wear more even.
With the hand tool in the trunk I had to push pretty hard on the lugs but its so short that I bet I am some where around 80lbs torque although with a long wrench I realize I wouldnt have to push nearly as much. I didnt stand on it or get crazy but I did muscle it a bit more after the neighbor took the wrench and backed mine off super easy the first time around.
I really hope they will be alright and that I didnt over do it but I have never torqued a wheel before and the 2 neghibors dont either with zero problems. Also while at the dealer I watched them rotate my friends wheels and they just use a air gun. Unless I missed them finsih off with a torque wrench I dont think they used one either. Now days most shops dont torque which sucks but thats not to say its a good thing.
For these tires my new method will be to self rotate at 2500 miles and torque then at 5k miles oil change with balance and rotation again. They wear too fast to not rotate often and I want to buy them again so if I can get 20k out of them I will be happy and choose them the next time around.
PS after you guys torque to 80lbs can you still budge the lugs or are they tight when checked with a solid wrench?
