disc brake conversion
Could anyone give me a rough idea of whats involved in transforming the rear brakes from drum to disc on a 99 protege?
thanks
James
I was thinking about doing this on my 1.6l. if you find out whats involved, could you fire off the info to me?
thanks
not worth it
He may have been blunt, which is why I'm stepping in, but he sums it up quite well. I wont elaborate much on this subject but to do the job, considering effort and cost it isn't worth it. Sometimes cost is the issue with people, sometimes it's the effort/work involved....some people it's both. Furthermore, for the trouble and money spent on the disc conversion it would be better off to spend a little more on higher end shoes for the drum which last much longer than discs anyways.
If this isn't enough elaboration for you, then you DO need to search, but I will tell you that the place you need to search is in the FAQ's.
Similar Threads and Articles
