DGM Molded Dash installed
Equinox
Daddy Warbucks
Contributor
09 370Z Nismo
pictures taken after the suggestion of a PM asking about em =)
Exactly how much did that cost for all the pieces?? Is it one full kit, or what? I thought they only sold a 4 piece kit, but that one looks like 5 or 6.
5 piece kit, although the cupholder is actualy two pieces but only counts as one.
The steering whele is not carbon fiber, I dyed the dots in it silver like the MP3 steering wheel only not silver all over, something I did a while back.
79$ a piece, from DGM
well you have to know how to take off each piece of interior to get it all to fit right. So depends on if you know how. I made a how to for the center console. In the how-to section
that peice is realatively easy i believe it pops right out derrick, if not take the glovebox out and see if there are any screws. But from what i understand its a pop in pop out peice.
here are I think three screws in it, then you can pop it out, one you get to from the outside part of the dash when you open the door, take off that panel and you will find ascrew if you look at an angle to the back of the pad.
Another in the top center of it, up under the dash above a chassis reinforcement bar (looks like rollbar tubing)
I took the glove box off first to get to it. You remove the glove box by just opening it, and pulling the two plastic side walls of the box together, and it will fall all the way forward.
I think only one more on the driver nearest edge of the pad, you may have to pull out a little plastic a/c ducting piece, it just comes out.
I used a very short phillips screw driver for all this, it is very crampeed, make sure you have a shorty phillips. Once you get all the screws out, just pull the pad off, pulling by the bottom edge.
Really tho, if you can't get all the screws just get the few you can, and pull it off real hard. Small little plastic 'poles' hold where the screws go in, so you can break these with some force, and even if you break these off, there are a whole lot of clips that hold the pad in, if you break all the little screw poles, it would still fit back on tight and flush, perfect. Do have patience tho.
nice. like it all, except the big DG on the glove box thing. wouldn't do that unless im sponsored by them or something.
ya i was goign to say that. the whole kit looks SWEET until you get to the cover and its got a big dg motorsports on it. why do they have to do that with all of their stuff. but the car looks good man. when you said $79, does that mean you can buy each separate.
::two thumbs up:: u sold me.. why is it we have the same taste? -=)
thanks for the flicksbro.. much appreciated.
John
L8R said:
nice work man. u think it was worth the investment? - chris
I think it's a little too expensive for what you get, but hey, I'm looking for a wow factor since I almost got beat out at the last show by a p5 with a slightly better interior then mine.
yes you can buy each piece seperate, although my car shoudl be teh only iteration with the cupholders that flip up, I don't believe they will make anymore as the batch they made I didn't approve.
Also the sticker on the passenger pad doesn't come on the carbon fiber, I stuck it there, for when I'm in show, thanks for insulting it totally =)
