- MazdaSpeed 6
bend the metal shroud inside the light untill its small enough to pull through the hole and bam.. done.
I got the TSX projectors with new bulbs off ebay for 150 shipped. I am loving the change as the stock ones suck.
Tony
Just got my D2S bulbs for the lowbeams, and have read all the pages from #1, and everyone says to take off the bumper.
I was looking at it today...havent taken the bumper off.
Easy to pop off the rear bulb cover then the power socket to the bulb. But then how do you get the bulb out? I dont want to break anything. Do i just grap the bulb base and pull out or do i have to twist ? Looks like there is a larger holder that covers the bulb base so not sure to pull or twist out that instead?
Help form anyone that has removed the bulb.
Thanks
I tried that then realized quickly why i had to take the bumper off. The bulbs are held in by a round retaining ring which twists on and when u are trying to line up the bulbs in the corresponding slots and then get the ring on and twist it you soon realize what a pain in the ass it is. If you need i have pictures on how to remove the bumper, really simple and easy process.
i'm trying to hook up the replacement low beams but the ones that are stock are just the bulb while the ones i got from ddmtuning have a few wires set up with them. any clue how to hook up, pictures preferred![]()
k i installed the fogs last night, now i know what you meant by the "metal shroud". i thought that was the tip of the bulb lol (crazy)
i ordered the replacement bulbs but i'm thinking i need those adapter cables to change it from the stock "round plug" to the "multi-wires" that the ddm bulbs come with to hook up, which i didn't order, so looks like i will be ordering those today![]()
