Between the trunk skin, the old latch and cable, and the key-lock, the ol' girl lost a solid 5 pounds. There'll be about a 1/2lb or so to go back in from the trunk-pins, but considering how little is left on the car, being able to find a chunk of weight in the "pounds" category is a solid win. It's not the 12 lbs I've seen quoted elsewhere, but I also didn't remove the hinges or the pickups for the hinges on the trunk, so that probably makes up some of the difference, but I consider that "good" useful weight. IE: I can still get in the trunk without too much fuss and use it to move gear between paddock and grid.
