bpt323 FE3-323 : Madison, WI : Mazda 5, 323 Jan 23, 2015 #1 What is OEM max recommendation? What is the maximum before the motor actually becomes interference? or What is the max you've heard of safely shaving off?? thanks in advance
P Preferio I break stuff. Contributor : 2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6 Jan 24, 2015 #2 bpt323 said: What is OEM max recommendation? What is the maximum before the motor actually becomes interference? or What is the max you've heard of safely shaving off?? thanks in advance Click to expand... I'm sure you've located the information by now, but in case you haven't, the maximum machining is .006" on the head if I'm not mistaken.
bpt323 FE3-323 : Madison, WI : Mazda 5, 323 Jan 24, 2015 #3 No i didn't find anything. the FSM has s*** for information & I got tired of searching hours on end. 6 thou - is weak as piss even for an OEM max. im disappointed if that is the actual number. any ideas on what crazy numbers others might have done?
