cylinder head shaving/resurfacing.
bpt323
FE3-323
Madison, WI
Mazda 5, 323
What is OEM max recommendation?
What is the maximum before the motor actually becomes interference?
or
What is the max you've heard of safely shaving off??
thanks in advance
or
thanks in advance
I'm sure you've located the information by now, but in case you haven't, the maximum machining is .006" on the head if I'm not mistaken.
No i didn't find anything. the FSM has s*** for information & I got tired of searching hours on end.
6 thou - is weak as piss even for an OEM max. im disappointed if that is the actual number.
any ideas on what crazy numbers others might have done?
