Cx-7 stumbling idle
86yotajunkie
2007 mazda cx7
my cx7 has 50k on it and lately when i fill up it idle rough till i put it in gear and drive it any idea what would cause this (limb)
If you over fill the fuel it will mess up the charcoal in the evaporation system. When you start it the engine must clean out the excess fuel & vapor before running correctly. Just stop adding fuel with the first pump click off. If you've been over filling for a long time then the system my be faulty and need parts replaced. Ed
Any CEL's?
I'd pull your MAF off and clean it for sure. Also check for vacuum leaks.
yea there is a o2 sensor CEL but i didnt think that would cause it to stumble everytime i fill up
Depends on which O2 sensor it is. An upstream sensor could mess with A/F and whatnot, not to mention hurt your mileage. Get it replaced.
yep. o2 sensor. i had one short out and it ran like absolute garbage until it was replaced. it ran fine at WOT, but starting from a stop was a frightening experience.
