CX-5 Turbo vs Non-Turbo
Status
Not open for further replies.
'20 Sport '25 Turbo
There is a lot of chatter about n/a and Turbo and the pros and cons. We recently bought a 2025 Turbo Premium to add to the fleet and supplement our 2020 Sport (base). Other cars in the garage are a 2018 Porsche Macan S and a 2010 911 S. The CX5s are "mostly" for our daughters but we drive them too.
I was torn going Turbo or n/a for this car. I personally like the feel and instant response of the n/a and think it punches way above its weight. Sure, it's weak in terms of highway acceleration and passing, but around town it's fun.
After a few hundred miles in the Turbo, I had a couple thoughts:
- The vibe of the turbo is confident and effortless, and not at all "high energy"
- The n/a is more playful and fun until you run out of power at higher speeds
- You just "loaf" and ride the torque in the turbo. It feels like a turbo diesel in that regard. Not a bad thing, just different
- Turbo is more confident at higher speeds. Combination of the torque, the weight, the suspension tuning (including the larger swaybars)
- Interior of the higher trims (this isn't a turbo thing) is VERY nice. That said, I still dig the cloth in our Sport
- If you need speed, you can add throttle in the Turbo and it just goes -- without fuss. n/a will be shifting down and revving a lot and gaining a lot less speed in the process :)
I've had several fun turbo cars in the past. My wife's Macan is a twin turbo v6. Laggy and can a be caught "dead" sometimes in a scary way. The Mazda is *never* without torque. Feels like a big lazy engine.
Also had a tuned Miata Turbo ('00). That was a "fun" turbo that built power up high. The CX5 isn't that.
Anyhow, I'm happy with the decision. It makes me appreciate the turbo but also really appreciate the authentic value of the n/a cars.
Mazda's turbo feels like a diesel engine.
Got two CX-5s myself. '17 CX5 N/A and '22 CX5 Turbo.
Sold the '17 recently.
I agree with OP's assessment between the two engines.
Not sure about the diesel but I agree with the assessment between the two since I own both.
I'm still taking it pretty easy on the engine because I'm at 300 miles and still running the fuel the dealer put in it. Based on the power and torque numbers and where they peak, it sure looks and feels like a "grunty" engine vs an engine that ramps and builds more power towards redline. Hence the diesel reference because they are low redline with massive low end power. I'm hoping the engine "opens up" a bit more with miles and the fuel that will enable it to build power at higher revs. Curious to hear from folks with experience on this.
What I read on this forum is the 2.5T can deliver a lot of power- but it requires a lot of fuel to do it. Maybe a special tune or careful driving helps deliver better FE.
Maybe the turbo is designed to deliver at the lower RPMs. Don't some cars have dual turbos to fix this?
we have had ours for 2 years and put about 35000 miles on it so far and I think the tranny makes a big difference as far as feeling torq down low. i use sport mode a lot and it will scoot...I have used all 3 fuel grades and not sure I notice a big difference between 87 and 91 (we have 87, 89 and 91 here) I have not really did a top speed run yet but I know at a buck 20 it is still gaining speed.
Mazda's intent was to design a turbo engine with a focus on low end power which would improve towing for whatever SUV they put it in. It was never intended to compete with engines that develop their power at high rpms. So don't expect it to "open up" with age.
Yep, big engine (for a 4), relatively high compression for turbo and a small turbo tuned for low end that spools up immediately. Seems like a good choice for an urban runabout.
They say the higher speed performance is enhanced with higher octane fuel.
I run 87 and have been for months now due to winter. When I do randomly put in 93 I can tell a difference. I have no gripes about the power this makes for a daily driver.
I can relate with my NA 6. It was always adequate and even quick in certain conditions, such as when rolling in low speed at second gear with the torque converter unlocked. Punch it, and the 2.5, FWD combo is able to pass cars with more power.
It's "lacking" at 80km/h+, but that doesn't matter, at least not to me. I would rather take my time and get better fuel economy.
Well at 5000 feet elevation here, I can't imagine a nearly 4000 lb and not low profile vehicle powered w/o a turbo at this 2.5L displacement, lol
My wife's car, so I had her drive both and she wisely chose the T
Maybe near sea level, non T might do...
I am at 3000ft and have been at sea level and I could not be happy with a na cx5. heck the longer I own my 23 turbo the more I wish it had more giddy up.
I took my NA CX-5 up Pike's Peak. It was fine. I don't remember it feeling lacking.
Driving up Pikes Peak a car can only corner so fast. unless they have the road blocked off for the road race it could be a real problem if somebody going down Pikes Peak was also racing around corners at the same time :(
Due to less oxygen at higher elevation, about 2-3% per thousand feet, all NA engines make less HP. Whether one feels it or not...
FI makes up for a lot of that.
I remember driving up Pike's Peak once also and had no time to feel it lacking in power, way too much fun.
Agreed on all points.
That said, if I do it again in the Turbo, I'm sure I will enjoy it.
We had a 2020 2.5 NA GT which for our use as a road trip vehicle was downright dangerous when attempting passes in the mountainous roads where we travel. Instead of allowing you to pass safely, the current crop of drivers perceive anyone attempting a pass as a challenge to their ego which requires them going into race mode. More than once I had to back off the pass because of the lack of power from the 2.5 NA. After a brief test drive in a Signature CX-5 I immediately ordered one to replace the GT.
If you are using your CX-5 strictly for city driving you may be fine with the naturally aspirated engine but for highway driving it is sorely lacking in acceleration. After owning the Signature I'd never go back to a non-turbo CX-5.
The 2.5NA is sufficient for passing if you do wait to do it safely.
Status
