CX-5 Strut Brands
Yeah, I hate a wallowing suspension. While the CX-5 is no thoroughbred, it does have fairly sprightly handling if the parts are all to-spec.
Am currently at 127Kmi on my 2016.5 CX-5, and I'm anticipating that after 150Kmi on the clock I'll be swapping-in new shocks front and rear, along with whatever control arms and anti-sway links are showing the need for new.
Last summer, I did the front lower control arms and tie rod ends, to erase an increasingly-loud clunk in the front right corner. Handling got right back to 'factory', after that fix. But the shocks are clearly losing some of their 'zip' and will get replaced within the next ~30Kmi or so (more than a couple years' of driving for me). Keeping ahead of the maintenance curve, basically.
Likely going with the Koni Special Active shocks.
what springs will you be using?
150k is a good time to change out the originals. You can get 200k out of them if you don't drive aggressively or corner hard. My rears still seem to be in quite good condition.
How about Tanabe?
Haven't looked at any except Mazda OEM factory, Koni (Special Active), Bilstein (and Bilstein doesn't seem to support the 2016). Am in the "mulling" stage. Not really looking for a performance build, so I haven't considered coilover setups. Though I might consider modest lowering. Will figure it out within the next year or two, by the time suspension work is needed.
I would consider the KYB "Quick Struts" (They call it "strut-plus".) If you are not looking for performance and body drop. For about the same price, you'll get the complete strut assembly.
Based on my research, if I had a 1st Gen CX-5, I would get the Koni SA. They are not for cars with more than a 1" drop though.
@Lazy2.5 Great, after much more research, I think KYB is a safer option, considering the amount of work plus the alignment cost. Can confirm the noise is from the struts, now it has developed into a more pronounced way, which can be easily recognized.
If your alignment is already good, doing so after the strut change is likely to be unnecessary. Have the struts replaced without the alignment first and try.
If you want to do the alignment, then wait until the struts break in and settle first. (800km)
Right, I have seen people making some marks on where the three top bolts are before removing them, and fitting in the new struts and bolts exactly where the old ones were, to avoid doing an alignment. I am going to do it this way I guess. Thanks for reminding me of this!
New Threads
