These worked out quite nicely, especially the inner plate. All the protective coating has not yet been removed. I left it on so you could see the writing better.
The items were sourced from China on eBay. Seller is very communicative, and shipped in two boxes due to weight.
http://www.ebay.com/itm/Stainless-Steel-Door-Sill-Plate-Scuff-Protector-FOR-Mazda-CX5-CX-5-2012-13-8PCS-/140972753282?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACX-5&hash=item20d2a18182&vxp=mtr
I had to use extra 3M double sided adhesive. Tried a roll of 10 lb tape, 1 inch wide and applied over the Seller pre-installed 1/4 inch 3M tape. Also added strips in the center portion of the sill trim pieces.
Edit: cannot get pictures to show up....will try another method
