- Plano, Texas, USA
Engine Coolant Level
Plastic engine coolant tank we normally see checking coolant level is the expansion tank for overflow and you're supposed to check the coooant level in clod. Nevertheless the "Full" and "Low" marks are designed for cold coolant level. You do have plenty of extra space for coolant to expand when hot. In theory engine coolant level, like engine oil level, can be in between "Full" and "Low" marks, but we don't want living dangerously and want to keep all fluid levels at "Full" mark if possible!ummmm y'all do realize that the coolant should NOT be at the Full line when the engine is cold, right? The coolant has to be able to expand into the overflow tank when it gets hot. Filling it to the Full line when cold could result in the overflow bottle, overflowing, when the system gets hot. As long as the coolant stays between the Low and Full marks at all times, it should be just fine.
