First I am not a mechanic, all back yard OJT... I really like my 2014 CX-5 Touring, but I have had several problems like the parking sensor in the console going bad, I made a video on how to fix that
and my transmission is now whining after I changed the transmission fluid (apparently there is a shaft that is off center because of a design flaw)... but it shifts fine.
But now I ran into the heater core leaking, first it was throwing the P011A error... there was some heat but not much, so I flushed the heater core and the P011A went away, but about two years later it started to leak. The estimate to have the heater core replaced is up to $1400 because the usual approach requires taking the entire dash out, steering wheel etc... the job apparently pays about 8 hours. I did not want to spend that much, so I went online to LKQ and got a heater core shipped to my house for $126... and tried a technique I saw on a video about how to replace the heater core the easy way, but it was a two part video and they never put the second part out... so I made this video
to help anyone that wants to try doing this ;-)
I think with this video you could get this done in under two hours, it took me about three or four, going slow and figuring things out as I went... and recording it.
