2013~2016 CX-5 Fuel Dilution in Oil + Buzzy Engine
Recently did a oil change in my 2013 CX5 with 200k.
I have had this car for right around a year and it has always had a stronger oil smell than my other two cars (Toyota's).
I was wondering if this was the case with you guys as well.
I know this is a DI motor so fuel Dilution isn't out if the picture, but this is stronger than what I'm used to with my other DI car.
On a side note, when manually shifting, is the engine kind of buzzy -like you can feel it in the steering wheel when past ~4k? Or is it smooth as butter?
This engine certainly isn't as smooth as the 2AR in the RAV4 or the 4GR in the Lexus (not that I expect it to be), just just wanted a second opinion.
Thanks!
