Current Engine bay pics everyone
really? i have an aftermarket can...6 yrs, no problems until recently, it's leaking...that's weird?
Oh yeah i have, but don't know why but car overheats if i use something else, i had Weapon R Aluminum Coolant can, and had to remove it, car were mad overheating with it..
Miguel, I don't want to go too off-topic here but where was the pick-up on the WeaponR coolant bottle? I also am using a WeaponR coolant can but the pick-up for the radiator line was at the top. You have to insert a tube and make a "straw" so the hose can grab coolant from the bottom of the can. If you don't do this the radiator will only take in coolant from the bottle when it's completely full - otherwise it'll just be sucking in air. I don't know if you've done this or not but it may explain your overheating.
yeah, you are absolutely right, i found that out about the Weapon R when i gave it for free to a friend of mine... I'm going to try to find some aluminum coolant can here, to give my engine bay a lil more bling....
I also have the Weapon R and instead of the straw technique, I simply used the drain plug on the bottom and a standard barb fitting from Home Depot and it works by gravity, just like the stocker. No problems with it in two years or so, I don't even remember when I installed it.
my any chance do you have pictures of it ?
i had the weapon r setup like yours and mine was constantly leaking. i redid all the fittings with teflon tape, and sealant (seperate times) and i would constantly see it empty. i know it was the tank cause my rad is always full. I switched back to the stock one and no problems. I just sold mine for 20 bucks and let them figure it out cause i had no idea cause im inferior.
Yeah I used teflon tape as well, no problems on my end. Weird.
Some changes were done, paint the intake black, and relocate the Oil catch can hoses, here is how everything came out !!!
^I'd leave the cover off. Unless you have OEM plug wires under there. The red is awesome! Also get rid of any fake Mazdaspeed eBay stuff. Just does not fit with such excellent work in there.
just wondering what fake Ebay Mazdaspeed Stuff ?
miguel:
I think he means the cloth cover over the power steering line lol
*shrugs*
ebay stuff never bothers me, long as it works hahaha
current engine bay pic:
(LOLOMGWTF???)
sub'n lol
miguel:
*shrugs*
(LOLOMGWTF???)
sub'n lol
ohhhhh,, hahahaha.. Bro i left that s*** one day to get dry, and i have forgotten to remove it...
damn, that's a sad Engine bay shot.. i hope when you come back here posting you have monster in there boosting s*** load of PSI, you know what i mean !!!!!!!!!!!!!!!!!!
Hahaha, Ebay is not bad if you know from who and from where to buy your stuff.. they sure have great deals on genuine and legit parts....
Might also have somethin' to do with the 400hp he's pumping out!
Well the car is not overheating anymore, the problem were the cheesy Thermostat I had before. added a JDM one and problem fixed... car is running like a rocket !!!
About the Weapon-R Coolant Can, you needed to do some s*** inside to make it work and for your car not or overheat !!!
