Cracked Fog light
sick_role
07 MS3
noticed my passenger fog light cover is cracked and there is moisture on the inside. Do I need to buy a new assembly or would I be able to find just the lens?
You can get just the lens.
Part numbers:
Left = B37F-50-C22C
Right = B37F-50-C12C
Should be about $15.
woal< I just learned something...didn't know you could get just the lens....good to know.
That part number is not for the glass lens. That part number is for the plastic shroud attached to the bumper that goes around the foglight.
Unfortunately you will have to buy a new foglight housing...aftermarket suppliers (Depo brand) pricing ~$125 per side. Amazon.com had them the cheapest that I have found.
BA6R-51-680B LAMP(R),F.FOG
BA6R-51-690B LAMP(R),F.FOG
I think sok07 might be right. I'd give your Mazda dealership a call. Or I like to deal with the folks at Rosenthal Mazda: www.finishlineperformance.com
The part numbers in post #2 are for 50-026.
That's right. I just bought one online for $140. Dealer is $295. The entire housing assy.
summbitch. Thanks for all your help. As soon as I saw that damn thing cracked I knew it wasn't going to be cheap. But, it does make sense that you can't buy just the lens portion. That probaby wouldn't seal very well if the light was designed to where that portion was easily replaced...thanks again. At least the light still works, for now.
